Old May 23, 2012 | 09:14 PM
onehundred80
Default Re: Braking Vibration
Originally Posted by Cedar11
I do not have spacers, everything is stock except the sound system. I have looked at the front rims and they do not appear to be bent. If they were, wouldn't it cause vibration without braking?
I will apply brake grease to all the pads to see if it helps with the squealing.
Thanks for the input guys.
If the rotor is warped then you can feel some vibration through the brake pedal. Is that the symptom?
NA rotor thickness, front =28mm (new), minimum = 26mm, rear =9mm (new), minimum =7.4mm
SRT rotor thickness, front = 32mm (new), minimum = 30mm, rear = 22mm (new), minimum = 20mm
Minimum size above is the service limit, that is the minimum size after machining. Wear after this not exceed .6mm total and only .3mm total on the NA rear rotor.
There are some size errors in the Repair manual.
