Old May 23, 2012 | 11:25 PM
amx1397
Default Re: Finally lowered it
Originally Posted by Mike1118
Thanks Amx. So the idea is to get right front left rear to equal left front right rear weight.
not really but almost,, you want more weight in the right rear than you do in the left rear but the X of the car the weight must be the same or as close as you can get it
example left front 1000 lbs right rear is 900 lbs=1900#
then the right front could be 1050 and the left rear should be 850 =1900#
also first weigh the fronts both = 2050
both rear weight ==1750
the best would be fronts weight 950 each and rear weigh 950 each ,,this includes the driver's weight in the front seat. jim
