Old May 25, 2012 | 06:54 PM
awilson40's Avatar
awilson40
Default Re: Trans fluid type revisited
Originally Posted by rcompart
Mercedes ATF Transmission Fluid MBZ Approval:236.10 001989210310 - RM European Auto Parts
This is the exact same 236.10 fluid Mercedes used to sell without the MB label on it and is the correct spec for the 722.6 transmissions.
You can use coupon code SUMMER2011 for 3% off your order up to $150.
I'm getting ready to do this service and I have records showing that the dealer has topped off the trans with the MOPAR 236.14 fluid when they fixed a leak.
Am I safe to use the 236.10 when I drain and replace the filter knowing this would not completely flush the system ?
thanks
