Re: Lowered cars... improve your ride...
I have the MBZ camber bolts as well, and all they could dial in was -1.6 max, won't get any better using the MBZ bolts as they only give you .5 degrees, come to find out. So, either a KMAC bushing kit might be in order, or camber plates (if you can find them... which apparently nobody can). Others can chime in, but at my KW-V2 lowering height with rake (1 finger in front, 2 fingers in back), I'm at -1.6 left and right front, and with MBArts' camber arms in back, I'm at -1.4 both left and right in the back. Rides great, no contact, no cutting or shaving. I don't track my SRT6 though. So you hard-core track guys might find it different for other in-use suspension setups and alignment settings.
