Old May 28, 2012 | 11:08 AM
  #42 (permalink)
tunaglove's Avatar
tunaglove
Default Re: Going to inject it with water/xxx
Originally Posted by velociabstract
Stock rail, stock pump, stock injectors, almost stock power with this retune. I may have picked up some air in the fuel lines as I was running the car near empty but I've seen spikes before. I forgot to log all my runs so I'm not sure. Note to self, write down everything as close to real time as possible! A fuel pressure gauge at the rail is coming soon. At my power levels and boost levels no one believes I'm running out of fuel .... unless the fuel pump is going out.
Les
You are dumping so much fuel because of your high engine temps, that you are hitting the limitations of your fuel system. So why would you try to even fix that? So you can have plenty of fuel to run 9AFRs? You need more cooling not more fuel.
