Old May 28, 2012 | 06:01 PM
Billy22Bob's Avatar
Billy22Bob
Default Noisy Roller/Rocker/Tappet.....
Changed the oil on my new SLK32 (80k miles) - oil was dirty and thin, filter was clogged, my oil extractor syphon pump stopped a couple of times duirng the change due to what I suspect is sludge in the sump.
Anyways - it has new Mobil 0W40 in it now and a new filter. Will change out again in 600miles along with a sump drop and cleanout/inspect bottom end etc. Change oil level switch.
After I changed the oil - it seems to have developed a single tick (2 per second at idle) from one of the RHS rockers/valves. It's only intermittent, I'm thinking more noticable when cold.
Recommendations?
Previously with motors (4cyl), I've lifted the rocker cover and analysed the problem and adjusted - however with this V6 I'd imagine this would be a very messy business - the banks being on angles I mean.
Also I suspect the gap may be adjusted through shims (?), as opposed to screwed and a lock nut.
Thoughts/links?
Any other business I should be attending to whilst I'm in there?
New gaskets if I do it - or just be careful and reuse the old ones?
Last edited by Billy22Bob; May 28, 2012 at 07:13 PM. Reason: change oil grade to 0W40W
