Old May 29, 2012 | 09:28 PM
amx1397
Default Re: Finally lowered it
Quote:
Originally Posted by 32krazy!
jim why do you want more weight in the right rear of the car as opposed to the left rear?
Originally Posted by JHM2K
Because he is in the left-front... ish.
And the right-rear, if I'm not mistaken, is the one putting the power down 90% of the time.
MY 200 lbs makes the right rear lighter,, anyway I'm not 100% sure but Rennteck is. they are going to be doing the balancing.
Don't forget when you balance the car you also add the drivers weight to the driver seat and then get the weight set in the rear, offsetting the drivers weight, so all four wheels could have a different amount of weight on them and still be balanced, when I get the car balanced We'll see what it does at the drag strip,will let you know.jim
