Old May 29, 2012 | 11:14 PM
amx1397
Default Re: Finally lowered it
Originally Posted by 32krazy!
i was thinking it was drivers weight. how do you plan to get 100 lbs to the right rear?
by adjusting the coilovers, you can change the weight around you may not get fron to rear or left to right the same and that is not the point... remember seeing cars at the drag strip with the left front tire in the air,, this car is not balanced but when both front leave the ground the same the car is perfect. jim
