Old May 30, 2012 | 08:26 PM
jrf05's Avatar
jrf05
Default Re: Low Fuel Light Flashing
Originally Posted by robby363
If you try to squeeze more gas in after the pump clicks off the first time it causes the gas to overflow into the evap tube and will make the light flash. I use to try to squeeze more in to top it off and when it got to about a half tank mine use to flash. It's never done it again sense I stopped filling after the pump stops the first time.
Yeah that makes perfect sense, mine is sitting a little under a half of a tank, I guess I was just trying to figure out if it was something bad or not. That is really odd that the system causes the light to flash for that!
