How to: Replace Clutch in '04 Coupe
Jun 3, 2012 | 01:27 PM
permalink
aallman72
May 2006
92
Dallas
Re: How to: Replace Clutch in '04 Coupe
Removing the Clutch Cover, Disc
20. Remove clutch cover bolts 1 to 1 1/2 turns at a time, in a star pattern. Making sure they come off evenly as to not warp the clutch disc. (
link
21. Remove cover/pressure plate, warning its heavy. I used a rubber mallet to loosen.
link
22. Remove clutch disc
link
23.
WARNING
, do not try to remove pilot bearing with blind hole puller as stated in service manual.
On a Dual mass flywheel
you will only destroy it
link
Like I did...
Destroyed Pilot bearing
link
At this point it became necessary to remove flywheel.
link
Up Next: Removing Flywheel...
09:50 PM
aallman72
View Public Profile
Find all posts by aallman72
