Old Jun 3, 2012 | 03:40 PM
onehundred80
Default Re: How to: Replace Clutch in '04 Coupe
That's great and an important addition to the knowledge base here. Five stars for you.
Are you going to turn it into a PDF file? I'll do it for you sometime if you want. That way it's easier to print out.
I think you could add that it may be a good time to replace the flex disks in the drive shaft if they show signs of cracking.
The blind hole puller is used when the pilot bearing is in the crankshaft which is where it is shown in the manual if I remember correctly. Another error in the manual.
