Thread: SLK32 Gauges
Old Jun 7, 2012 | 10:41 PM
JHM2K's Avatar
JHM2K
Default Re: SLK32 Gauges
Originally Posted by Trenzman
White Face gauges? I could just swap the cover as long as everthing lines up correctly, I would hate to run out of gas with it still showing 1/4 of a tank.
If you just want white gauges and don't care about an increased max speed calibration on the gauges (honestly, 160 is fast enough) then I would HIGHLY recommend just buying a set of SLK 320 gauges from ebay. Buy the ones from 2001+ as the finish is a crisper white than pre 2001. See attached photo below, the top one is the style you want.
Also, refer to MMZ_Timelord's gauge color thread... instead of fooling with the paint sanding step, simply install the white SLK overlay in place of your OEM black one, and VOILA!!! You have white gauges, a functioning fuel gauge, and you retain *exact* mileage.
If I had another N/A this would be my first mod, as it looked brilliant.
