Old Jun 11, 2012 | 03:40 PM
onehundred80
Default Re: Braking Vibration
Originally Posted by freakingfastsrt6
No offense, but if it were me and I have been selling and installing performance brakes for a little more than 10 years...If one rotor comes warped to you....Why on earth would you want to go with that same company again? Spend the money on a product that secures you up front. There is a lot of garbage being sold online and I hate seeing people get ripped off on a daily basis.....I need to do another write up on bad rep brakes and good ones to buy. If you ever have any questions or concerns on brakes please send me a pm.
My guess is the rotor is not warped, if the screw is too tight I would guess that the rotor is not tight up against the hub. If the screw is hard to turn then it may have cut a slight thread in the rotor and you can not tighten two items together when each carries a thread until one of the threads is stripped by the tightening forces. It actually may feel tight, as the screw side will be tight and the other side will be clamped down by the screw side force. A rap with a hammer on the top hat may loosen it though. Also the screw may be stripped by now and it may indeed be a warped rotor.
If you have a run out that is easily visible then that is extreme run out, normally you would need a dial indicator to see a run out that would cause some vibration. I think .004" is the max T.I.R. in the shop manual, I could be wrong on that though.
Strange he mentions the rear rotors as being badly scored, as SparkieSRT6 and I have badly scored rears and smooth fronts.
Well the answer came as I typed so the outcome is positive.
Last edited by onehundred80; Jun 11, 2012 at 04:24 PM. Reason: Answer came while typing
