Old Jun 12, 2012 | 03:25 PM
Infinity's Avatar
Infinity
Default Re: Feeling some vibration
Originally Posted by Silverarrow
Hi!
I'm feeling some vibration in the car as soon as I reach 40mph. Then the vibration is decreasing for each mph until I hit 50mph and then it dissapears.
Does anybody know what it could be? Could it be the driveshafts?
check wheel balance, alignment, and brake rotors first to make sure things are running true. also check to make sure the tires dont have any flat spots if the car has been sitting for a while. From there check the inner and outer joints on the steering tie rod assmebly for excessive play or damage. those are your cheap fixes, then its off to examine drive shaft coupler and shafts.
I have had the same issues and found that the sliders on the break calipers were binding up and sometimes casue the break pads to rub the rotor on one side. The tie rod ends need to be replaced at some point as they are showing signs of wear after 127000 miles
