Old Jun 12, 2012 | 08:09 PM
Billy22Bob's Avatar
Billy22Bob
Default Re: Looking for some details on the SC Heat Exchanger/Cooler...
Originally Posted by MrMoPar
The SRT6 does not use a MAF sensor. Only a MAP sensor. The supercharger discharges down in the front area and the air travels backwards through the intercooler and discharging from the rear. You could drill a small hole in the front of the intercooler and epoxy a thermocouple in the air coming directly from the compressor. Compare to the IAT reading to give you the delta.
note - I'm trying to decypher my Carsoft 7.4 real time figures from these sensors.
So stock see if I have this correct.
  • AIT's are measured pre compressor on that little sensor prior to the SC
  • A MAP sensor measures the pressure in the inlet manifold (after the SC)
So what happens next....? I will guess - to see if I'm on track.
  • From the AIT and MAP - the ECU calculates an "inferred" air density at the valve port.
  • The ECU than calculates a "mass" flow grams/sec based upon displacement (bore x stroke) and density which is reported to the Fuel map.
  • The Fuel map relays a grams/sec mass required from the injector - eg: say 1/12th of the air.*
oila!
please correct where applicable please.
other -
*Is this map simply 2 dimensional? temp v AFR? or does the map take into account other inputs?
