oledoc2u
... I have a cheap terminal wire brush I use...I am sure I am leaving something behind, but, I don't care...
Doc, you're not leaving anything behind-brass is harder than the lead. Best choice as it doesn't gouge the crap out of the terminal either!
One of the worse choices is the "scraper" type that actually cuts away material-unless someone beat the post with a hammer and you need to re-form the taper.
Valk-I hope this does it for you!
If so, you can close this thread!
