Re: Where to mount the O2 bung for Zeitronix lambda?
because the wideband O2 goes before the oem narrowband in the exhaust mani. its closest to the engine and farthest place away from the cats. you have less than 6" from the exhaust flange to the cat to work in and you want the 02 sensor as far away precat as you can get because the heat degrades them over time. that only leaves the exhaust mani
