Old Jun 22, 2012 | 07:32 AM
ala_xfire
Default Re: License Plate Lights Problem -- Blown Fuse?
1. INSPECT THE LICENSE LAMP BULB
Note: If both license lamps are inoperative, inspect Fuse 11 located in the Illumination Control Module/IP
Fuse Block. If the fuse is open, repair the cause of the open fuse before continuing.
Turn the ignition off
The IP is the little fuse panel at the left side of the dash under the plastic panel that has 2 coin-slot screws.
Sounds like you may have more than 1 blown fuse .....
