Old Jun 22, 2012 | 08:32 AM
caddymike85's Avatar
caddymike85
Default Re: Question on front bumper removal
James is right, removing the front wheels makes it a ton easier. Doing that will allow you to remove two screws from the wheel well lining and gain access to those screws. I find that it is easiest to use the 10 mm socket with an extension. Get the screw nearest the door by going through the wheel well and get the nut closest to the front by removing the turn signal light and passing your ratchet through the opening. Don't forget to unscrew the foglights too, its a lot easier then disconnecting the harness.
