Re: LED Inside Headlights...Audi Style DRL
Jonctovar, thanks for the write-up. I was hoping you might could go into a little more detail about cleaning up your headlights with the sandpaper. I used a cheap kit by Turtle Wax earlier this year and already my headlights are back smudgy. From what I understand, you rubbed with 1000 and then 2000 grit sandpaper and then sprayed a thin, even coat of clear enamel. Would you mind going into a bit more detail on how long you sanded with the different papers, like what to look for when you know you've done enough. Thanks! Seems like a great method rather than having a body shop put a new clear coat for $100+. Thanks!
