Old Jun 25, 2012 | 12:48 PM
  #55 (permalink)
dinasrt's Avatar
dinasrt
Default Re: Going to inject it with water/xxx
I would guess that the AC runs the fan at 50% and idleing for a while really does not produce much heat. The supercooler had a nice constant air flow throught it with little heat to reject.
That sounds precisely right. Regarding the Meth/Water injection; have you experimented with larger nozzle Les? I know that Rodney at AIS says to use a much larger nozzle (pre SC) than what you originally mentioned you were using. I know that some use dual and tri-nozzles in a cooler climate than where you're located. There are many variables I know, but I think the real question would be; how hot would it have been w/o the injection? It would be very disappointing to find out that all these MethKit manufacturers claims are BS.
