Re: Going to inject it with water/xxx
I presume you read my note about doing the KC post your IC, rather than KC's design where they install it pre IC?
You wanna max your delta T's but also minimise load on the AC if possible - so let the IC do what it can first then clean up with the KC pre cooler pump.
