Re: Going to inject it with water/xxx
32krazy! : i am waiting your result with the KC down on the track, you should be able to get the AC work at wot with the development data with star diag. i don't know which code but i think it can be.
velociabstract: you have to install the meth kit after the SC not before to get more results, also i think you have a problem in the cooling system as i see you have the supercooler radiator and with the 178 pulley, you should not get IAT at 170 at high speed before injecting, i have 185mm pulley ( more heat then 178) and a supercooler and another he and i don't see more then 155/160 F at high speed. what is the ambient temp when you test?
i installed before a meth kit on an E55 with 180mm pulley and i got good results between 20 and 30 F decrease in AIT.
