Old Jun 27, 2012 | 03:40 PM
  #75 (permalink)
dinasrt's Avatar
dinasrt
Default Re: Going to inject it with water/xxx
Originally Posted by Robert AMG
Do you have place down to install the stock HE in series with the supercooler?
I'm pretty certain that if you wanted to do this(run two heat exchangers), that it would be best to run them in PARALLEL, not in SERIES. In parallel will get you much better flow. The Supercooler obviously flows better than the stock H/E, so why would you connect the lower flowing H/E in line with it? If I did this, I would neck up to larger diameter hose so that I could use a larger Y fitting at both inlet and outlet where you converge back to the stock diameter hose. The larger Y fitting would assist in keeping the best possible flow thru both of the H/E's.
