Re: plastic jacking point block
Thanks for the help, 2 questions.
1) The link did not work.
2) The bottm of my car (see with the pad off) has both a hole for the protruding center part of the pad to go into (the part with the 4 fingers) and there is an inch long 1/4" dia barbed rod sticking out of the rocker panel, it goes into a small hole in the pad itself.
The picture of the pad on ebay is missing the small hole for that rod attached to the car. If I ger the M-B pad, along with trimming ears to make it fit do I also drill a hole in it for the barbed rod?
Reason: spelling
