Shedman, if I may? Could I suggest you do a "how to", explaining how to do this "surgery" - swapping out the insides of the light with the LED strip?
It sounds like this 3rd. brake light assembly is prone to failure on these cars, and is not only expensive to replace, but often out of stock across the country at any given time. Mine is working ok so far, but I'm worried it'll fail and I'd rather do an inexpensive, but effective repair like you described than buy another whole assembly.
shedman
The left hand side of the brake light not working seems to be a common fault.Mine went about a month ago and i managed to seperate the lens by carefully scoring with a knife.There are two led circuit boards inside.I have now fitted led strips inside which i got off ebay for 99p and stuck the lens back together.
