Archaic
Bosch 0 392 022 003 is the stock pump. If you purchase the Bosch 0 392 022 010 from amazon, be prepared to do some minor wiring. The I/C Pump that needswings sells is the Bosch 0 392 022 010 but they've including a wiring harness for it that I believe is plug and play.
Archaic - I am going to have to respectfully disagree on this. I just did this change out about a month ago and used the pump from Amazon and it was a identical match to the 003 that I removed, including the wiring. I tried to order from NeedsWings but he was only carrying the 003 at the time and hadn't started stocking the 010 yet. When I asked Rob at NeedsWings about the 010, he hadn't heard about them yet - we actually exchanged several emails about the pros and cons of the Bosch 003, the 010 and the Johnson. Since I don't have the tools to do modifications, I went with the 010 since it required no mods to the bracket or the connector.
RL
