BuffNSoFly
So my dilemma at the dealership started when I requested a State inspection to be performed but, they are trying to get me to replace tires with plenty of tread left....I have ~10k miles on my Toyo Proxes T1R's. Also none of those miles have seen the track only the highway.
I called bullshit on them and said I can't justify buying them now as they are good for another 5k at least. Problem is they DON'T manufacture T1R's anymore and are currently being replaced with the T1 model tire.
My only solution is to buy brand new rear tires that are a completely different brand. Has anyone ran different brand tires from the front compared to the rears before?
Part of me wants to be stubborn and ignore getting my inspection done and waiting until I feel I need tires. Either do this or take it to another shop for a second opinion.
Any suggestions?
Get your safety inspection performed somewhere else. (vii) probably gives the inspector a little discretion for things like excessive dry rot, deep cuts where ply/cord is not exposed, or where extremely irregular wear is noticed. But they shouldn't fail the tires because they are simply getting close to the minimum allowable tread. O course, it often makes sese to replace tires with closer to 4/32" remaining tread if you drive in wet weather or experience snow/ice (for cars equipped with all-season tires).
PA law...
Inspect the tires and wheels and reject if one or more of the following apply:
(i) A tire has two adjacent treads with less than 2/32-inch tread remaining at any point—less than 4/32-inch tread on the front tires of the vehicles having a gross weight in excess of 10,000 pounds.
(ii) A tire is worn so that the tread wear indicators contact the road in any two adjacent grooves.
(iii) A part of ply or cord is exposed.
(iv) A tire has been repaired with a blow-out patch or boot.
(v) There is a bump, bulge or separation.
(vi) A tire is marked “not for highway use,” “for racing purposes only” or “unsafe for highway use,” or has a similar designation.
(vii) There are other conditions or markings reasonably believed to render the tire unsafe for highway use.
(viii) A tire has been regrooved or recut below the original tread design depth except special taxicab tires which are identified as having extra undertread rubber.
(ix) A tire’s tread extends beyond the outer edge of the wheel housing inclusive of fender flares.
(x) The tires used on the same axle are not the same size or type of construction—bias, belted, radial or snow.
(xi) The wheel nuts or bolts are missing, loose or have improper thread engagement.
(xii) The stud or bolt holes are worn out of round.
(xiii) Part of the wheel is bent, cracked, welded or damaged so as to affect safe operation of vehicle.
(xiv) The rear wheel does not track front wheel in straight ahead position as originally designed.
(xv) The wheel base on one side differs from the wheel base on the other side by more than 1 inch, unless the vehicle’s design specifications indicate different left and right wheel base dimensions.
(xvi) Studded tires are in use after April 15 and before November 1.
(xvii) Retreads are on the front axle of a taxi.
(xviii) The diameter of duals is not within 3/8-inch of each other.
(xix) An axle has missing tires or rims.
(xx) A tire makes contact with the body or chassis. (xxi) Spacers over 1/4 inch in thickness are used to increase wheel track.
