Old Jul 5, 2012 | 05:34 PM
WES84's Avatar
WES84
Default Re: Battery in crossfire is being drained quickly,car will dies and wont restart
Originally Posted by alaxfire
Remove the negative battery cable and then connect a 12v light bulb between it and the terminal.
Use a backup light bulb or similar or a 12v test light.
Start pulling and reinserting fuses until you see the light go out.
Investigate from there.
did as you said and used a test light pulled all fuses and the light never went out...
