Old Jul 6, 2012 | 03:28 PM
JHM2K's Avatar
JHM2K
Default Re: Frozen Boost Heat Exchangers...
https://www.crossfireforum.org/forum...tml#post570633
I have the 3.5" thick one. It's an air to air core modified with end tanks, it also wieghs almost 20 pounds. avoid.
Very interesting, so you're recommending the avoidance due to weight or poor construction?
Reason I ask, is I was considering a used AMG h/e but this one had a larger capacity.
The 2" thick one should weigh less (slightly) but also holds only 54% of the fluid...
I know Rob's is the biggest and best h/e out there, but it's a bit 'spensive... my mod budget is limited until Kim and I get moved/settled into our new house.
