Old Jul 6, 2012 | 08:01 PM
James1549
Default Re: Broke the camber arm
Originally Posted by velociabstract
Rear KMac kit came in today. The surprise is that the camber adjustment bushing goes into the lower control arm inward connection point. I think Sunday will be the day I try and do it myself.
Les
I recall seeing that the KMacs go in the lower control arms. Does that mean you are going back to OEM on the top?
James
PS I still think that a set of upper arms like Mike makes can have an arch to them to clear the sway bar. It is just that you will have to remove one end to adjust them. Pain, I know, but it should work. I pre-adjusted mine to 12" OC before installing and never touched them since.
