Old Jul 9, 2012 | 08:41 AM
tunaglove's Avatar
tunaglove
Default Re: signal modifiers
Originally Posted by MrMoPar
I have been successful in control of closed loop fuel AFR's by applying an O2 sensor voltage offset. The ECU sees it as a lean condition and adds fuel to bring it back to what it "thinks" is the correct 14.7 AFR. I have used this for part throttle boost fuel control while still in closed loop and it works very well. I can control AFR to within .2 to .4 of my target which is fine for light load part throttle boost on a turbo.
This is what the S.S. Enricher is supposed to do. As you can see here offsetting the voltage does not effect the trims. The guys at S.S. where stumped also.
File Type: png
