Re: Roadster rear window problem solved?
Just another window detach victim chiming in. Original owner (in July 2004) of a 2005 roadster limited purchased from a WI dealer and titled and driven almost all 130K miles in MD. Separation just started on the lower corner of the driver's side. I'll check in with Chrysler but, based on this thread, I don't expect any help unless I bring my checkbook.
It looks like three home fixes are being discussed:
1. 3M Window-weld (including using the primer) - courtesy of mach2plus on 06-12-2011
2. Rhino Glue CA - from SETTER on 07-23-2011, and now
3. Loctite 5572 - from TrippleJ on 07-05-2012
It looks like TrippleJ is the first to try Loctite and will do so shortly. Can anyone provide updates on the 3M and Rhino Glue CA fixes? Anyone with thoughts to share about Loctite? I am tempted to try Rhino Glue CA first, but with TrippleJ breaking new ground on the forum with Loctite, is there something about 3M and Rhino I should know?
Any thoughts to share? I am curious and don't want to have to do it a second time!
Thanks!
