Old Jul 10, 2012 | 03:05 PM
onehundred80
Default Re: How to check alarm ?
The alarm system is armed in two ways;
1, The fob arms it when the lock button is pressed.
2, Locking the car with the key in the door will or should arm the system.
If locking the car with the key makes the module in the trunk operate and the light flashes inside the car, then opening the car through the open window will cause the alarm to work.
If the lights inside the car do not work then the slider switch on the light housing may be slid in the wrong position.
