Old Jul 11, 2012 | 09:10 AM
Semlinger's Avatar
Semlinger
Default Re: Needswings Dual Intake - Add-on Driver's side pipe and Y
I have an SRT 6 and have been thinking about the needswings catch can or an alternative. I recently unhooked the hose that goes between the drivers side rocker box and the stock cold air intake. i plugged that hose directly into a small filter i bought at WalMart for under $8.00. The little filter is bath tub shaped, the hose plugs right in. It is for a Techumci 6.5 horse lawn mower engine. I plugged the hole in the intake pipe (right side of the restrictive Y pipe) with a wine bottle cork. This is temporary. I want to see how dirty/oily the little filter will get over an oil change period. I realize the wear and tear on an engine and how hard you use it coontribute to the crank case blow by. Mine is still pretty fresh and not punished all that hard.
