Old Jul 11, 2012 | 05:17 PM
70GS455's Avatar
70GS455
Default Re: E85 conversion found!?
I would re-iterate, make sure you have enough injector duty-cycle to compensate before you start the conversion process. If you have over 70% worst case IDC, there is a chance the mixture will run lean with stock configuration. Not the end of the world if you still want to purse this, just means you will need either more fuel pressure or larger injectors.
