Old Jul 12, 2012 | 09:05 AM
onehundred80
Default Re: How to check alarm ?
Originally Posted by Goldwing_Don
Nope... nothing.. Not a .... Remotes don't lock the car so I did it with the key. Waited 10 mins or so and pulled the door handle from the inside.. No lights. No horn not a sound and she started right up.
Is there a relay or a door switch I need to start looking at that would cause all my problems?
When you lock the car with the key does the other door and the hatch lock? If not then the security module in the trunk may not be working, you should hear it operate when the key is turned in the door lock.
If it is not working you may find that there is water in the well that the module sits in. It is surrounded by a foam block, water can get into that well and ruin the module. Fuses #25 and 26 are in the circuit, check them.
