Old Jul 13, 2012 | 05:58 PM
  #184 (permalink)
rusty's Avatar
rusty
Default re: Hankook Ventus V12 evo K110
I put the 285/35/19 Hankook on the rear and have a serious rubbing issue that is driving me crazy.. I have koni adjustable shocks, TVT adjustable Camber arms and non OEM offset rims and near zero camber so it is hard to tell which one is causing the problem...I also had to put 15 MM spacers in the rear ....I am lower by 3/4 of an inch than other crossfires which may be the result of some of the mods..same tires and size but still has OEM shocks, rims and no spacers...after looking at the clearances I could reduce the spacers to 10MM and roll the inside of the fender a bit more than it is and possibly solve the problem. My mechanic tells me that with 75000 miles on the springs you could expect to have a reduction in road clearance so maybe replacing the springs is an option???? Any words of wisdom out there...sorry to interject with my problems but the subject seemed like a good place for me to ask the questions. Otherwise the rims and tires are awesome....cheers...Rusty
