Old Jul 13, 2012 | 07:07 PM
onehundred80
Default Re: How to check alarm ?
Originally Posted by Goldwing_Don
When I use the remote the lights on the outside of the car flash but nothing else happens.. When I get in the car and start it I push the switch inside the car the doors and hatch lock. There is no interior lights and no alarm sounds at all..
Did you check that the sliding switch on the light is in the correct position for the interior lights to come on? Does the light in the trunk work? If it does you may have a broken bulb or two in the overhead light.
I'll ask again, does the module in the trunk make a noise when you press the fob button, I guess not but you have never said so definitely or not.
The lights flash so the transmitter and receiver work, the receiver is not sending a signal to the trunk module. So seemingly the module is shot or the transmitter is partly broken. Check for water around the module in the trunk, you should be able to see if there is water down the back of the foam block under the mat in the trunk on the right side of the car.
