onehundred80
Did you check that the sliding switch on the light is in the correct position for the interior lights to come on? Does the light in the trunk work? If it does you may have a broken bulb or two in the overhead light.
Yes, the switch is in the right position. No , the truck lights do not come on
I'll ask again, does the module in the trunk make a noise when you press the fob button, I guess not but you have never said so definitely or not.
No, the module doesn't make a sound with the remotes... Nothing makes a sound. Just the outside lights flash
The lights flash so the transmitter and receiver work, the receiver is not sending a signal to the trunk module. So seemingly the module is shot or the transmitter is partly broken. Check for water around the module in the trunk, you should be able to see if there is water down the back of the foam block under the mat in the trunk on the right side of the car.
