Old Jul 16, 2012 | 02:06 PM
JHM2K's Avatar
JHM2K
Default Re: Need to know ASAP if these wheels will fit my NA crossfire
Originally Posted by MAYAman
I'm sorry my friend when it comes to wheels all I know is what looks good. thats Chinese to me
If I buy these would I be able to make them work without them looking ridiculous or rubbing? Sorry to create another question.
thanks. Do you have a link to those parts I'll need? Also, what does "machine down" mean? I don't have access to any machining equipment and will probably not have access to getting anything machined as insurance companies here in CT have all shops defensive.
That's no problem.
The spacers are carried by a number of vendors, the brand is H&R and the spacer thickness is 10mm.
Bolt pattern is 5X112.
The hub-centric spacers act as a centering ring for the wheel. Without a spacer on the front, the 8.5" wide wheel will make contact with the upper suspension nut.
You'd need at least 5mm of spacing to clear, but the 5mm spacers don't have the hub-centering function. only 10mm and up... 10mm would make the wheel stick out too far past the fender. So, 5mm needs to be machined (shaved) off.
Might ask if someone on here can machine them for for you?
