Old Jul 18, 2012 | 01:42 PM
  #78 (permalink)
crookedview's Avatar
crookedview
Default Re: Eurocharged NA Software and Remote cable sale!
Originally Posted by loungn14
see below.....or reset the battery. (will not remove the tune) Can you verify no leaks in the tb? Did you do a tb reset after install?
I've done a throttle reset and pedal reset, and when I installed the new intake and throttle body I made sure to get a new gasket for the throttle body. The elbow to the throttle body and intake is tight on both ends. I'll double check when I get home and will also leave the battery disconnected for half an hour or so. If that doesn't fix it I'll shoot an email over.
