Old Jul 19, 2012 | 01:26 PM
kuratsunade's Avatar
kuratsunade
Default Re: Footwell Illumination
Originally Posted by dtinker
Looks good to me, my Milan has those as factory std. Where did you tie in to wiring. In the door or overhead cabin light?
Thanks.
If you peel off the A-Pilar cover, there's a electrical tape covered set of 4 wires.
Tap into Red/Gray for "+", Brown/Yellow for "-". It will go together with the door control.
So when the door opens, LED comes on together with the map light. The door closes, LED will go off. If you turn on the map light, it will come on as well. If you use switch to disable the map light, they will not come on.
This way, it is easy to install. The complex part would be taking apart the center consul. However, if you only take off the CD Player, switches, you can sneak the wire through.
I'm also thinking about putting a set of these behind the seats, and wire it like the illuminated door sill, so it will come on by the door opened. (e.g. if only driver side door opens, the footwell for both will come on, but behind the seats, only the driver side comes on. Also want to figure out how to get the illuminated door sill change color by simple switches. )
Hope it helps.
Cheers.
