Thread: IC Coolant Tank
Old Jul 23, 2012 | 03:37 PM
  #50 (permalink)
oledoc2u
Default Re: IC Coolant Tank
Originally Posted by Semlinger
Have any of you who use two tanks for the seperation used alcohol (or windshield wash fluid) for the intercooler system? In the possible event of a leak in the intercooler core I would much rather see water and alcohol leak into my engine than eytheleen glycol prrmanent antifreeze. Old cars that used alcohol used 7 lbs pressure caps and 160 degree thermostats. The alcohol would boil away with a 180 degee thermostat. I do not think the intrrcooler water would normally exceed 160 degrees so it would not normally boil and therefore would not push water into a recovery tank.
this is kind of an older thread. I will have temp reading from my seperations after I install the a Dashdaq this weekend. Just not sure I would use alcohol for this. The innercooler leak haven't caused any real problems with the cars...just a pita to fix having to pull the s/c...
