1. Raise and support the vehicle.
2. Remove the fuel pump splash shield.
WARNING: The fuel system is under constant fuel pressure even with the engine off. Before disconnecting any fuel lines, this pressure must be released.
3. Release the fuel system pressure.
(Refer to 14 - FUEL SYSTEM/FUEL DELIVERY - STANDARD PROCEDURE).
NOTE: Place a shop towel around fuel lines to catch any excess fuel during disassembly.
4. Remove the fuel filter/pressure regulator fuel line (1).
5. Remove the fuel rail supply line (3) at the fuel filter/pressure regulator.
6. Remove the fuel delivery hose.
7. Remove the fuel return hose at the fuel filter/pressure regulator.
8. Remove the clamp retaining screw and remove the fuel filter/pressure regulator
