Old Jul 23, 2012 | 08:02 PM
randomwalk101's Avatar
randomwalk101
Default Re: Possible I/C Pump Replacement
Originally Posted by RL67037
Random
Not really sure what your set-up currently is. Has your I/C pump ever been replaced, and if it has, did it get replaced with a Bosch pump or a Johnson pump?
If, in fact, you still have the original pump in your car, and you order a Bosch 010 pump, you will not need a new connector. If you order a Johnson CM30 to replace your OEM pump, you will need a connector for the Johnson pump, which Needswings normally provides with the Johnson pump.
If, on the other hand, the pump that is currently installed on your car is a (replacement) Johnson pump and you are replacing it with a Bosch 010, then you will need a connector for the Bosch. I have heard (but not proven) that these connectors can be found at Radio Shack. Might be best to take the pump into RS and see if they can match it up.
Give us a bit more information on your current set up and I'm sure someone will chime in to help you out.
RL
Yeah I don't have stock connect which fits the 010 pump that's why I'm looking. Right now I'm using the 002 which I'd like to replace with the 010.
