Re: Adjust latch on rear of top?
There should be a rubber seal around the bottom edge of the back portion of the top where it contacts the tonneau cover. Yours may be missing if you have a leak. Mine latches tight enough to where it squishes down on the seal very tightly. If the seal is there you may want to check that latch out, might have a damaged mechanism.
