Re: Installed Johnson CM30 Pump / What triggers pumpt to come on??
rv the car to 2000 rpm this engages the pump until the car is shut off. or run a fused jumper from the pump fuse to the power block under the fuse box. this allows the pump to run whenever the ignition key is on.
did you check to see that you soldered the wires properly? neg to neg and power to power?
