Old Jul 24, 2012 | 09:02 AM
amx1397
Default Re: Lowered rear only
Originally Posted by velociabstract
How did the instal go? I think it looks great but ...... function first. I used a rubber spacer sliced out of an old spring pad. It made me nervous though.
Les
the install is easy 1/2 hour, because i have all adjustments links,,,I removed the lower shock bolt and the sway bar bolt and out comes the spring installed the new one.
MikeR That is pretty low..... looks lower than the Aero by a little....
mike it is not lower than the Areo but the 285 35 19 tire makes it look low . i will measure the finder to the ground today also put my 26" tire on it. jim
