Old Jul 24, 2012 | 09:50 AM
amx1397
Default Re: Lowered rear only
Originally Posted by +fireamx
What are you shootin for Jim, looks, or better weight transfer at launch?
the better launch,, to do that i have to balance the car,, I do need to raise the rear about 3/4" but the KW's are at their limits,, now that i have the KW's I don't like them. for $2000.00 they don't work,, when you have to remove the spring to adjust them " something is wrong" they say their adjustable "there not" when they say you can adjust the height and the spring rate "you can not. so to me, the KW so called coilovers are crap.
if someone made a coil over shock that installed upside down so the spring and the adjustment would be on the bottom like all coil overs we know, then they could call it coi overs for a Crossfire.
